Ok so im building my wifes 80 Vette. The instrument cluster case, for the speedometer and tachometer is cracked and i cannot for the life of me find another one anywhere!! Can someone please help me out?? maybe im looking under the wrong name for it? maybe im just dumb? i went to a chevy dealership and thats the name they gave me for the part.
I am also going to put in digital gauges later. should i wait to see if it will come with a cluster case??
Welcome to the Forum !
You've come to the right place to find the things you need !
You might want to go to the C-3 parts section and post a wtb for the part you need !
It will help to take a pic of the part you need and put it in your post which will help to identify it !
I have one still in my 1981 parts car, I can try and pull it out for you. If you have a list of things you want to find I can see if they are still good on my parts car and we can wheel and deal.
respectfully,
Will
hey that would be awesome!! ill pm you in you a little while. thanks so much!!
sadly no. its a huge crack down the top. the person before my wife glued it into the dash and i had to pry it out.
i tried to be as careful as i could but it was so stuck it was impossible to get it out intact. should of used some adhesive remover but i wasnt thinking. ugh.
There are currently several available on eBay.
Try searching for 1978-82 speedometer & tachometer instrument cluster.
May also try searching for a 1978-82 dash bezel.
I have seen them pop up using both terms.
