Upper/Lower control arm
Old Feb 28, 2018 | 11:18 PM
68vetteman's Avatar
68vetteman
Default Upper/Lower control arm
After installing new rubber bushings in control arms should the weight of the car be on the wheels to tighten the end bolts or should the wheels be in the air?
Thanks, 68vetteman
Old Mar 1, 2018 | 12:10 AM
cabman72's Avatar
cabman72
Weight of the car on the wheels.
Old Mar 1, 2018 | 06:50 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Exactly. Forum members advised me that the car body will "sit" a couple inches too high and the rubber inside the bushings will be torn to shreds in a few thousand miles if the bushing bolts are tightened with the "wheels in the air".
Old Mar 1, 2018 | 03:35 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Height
Upon reinstalling the springs after the bushings were replaced, did you index the springs correctly? Jerry
Old Mar 1, 2018 | 06:50 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Control arm ?
How about when installing lowers?
Does the vehicle need to be on the ground when torqued down?
Thanks,
Marshal
Old Mar 1, 2018 | 06:51 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Thanks,
Marshal
Yes
Old Mar 1, 2018 | 11:33 PM
68vetteman's Avatar
68vetteman
That is what I thought but I never saw that in my "Chilton" books.
68vetteman
Old Mar 2, 2018 | 12:55 PM
marshal135's Avatar
marshal135
Thanks Fred
Good info here never knew this detail.
Marshal
To Upper/Lower control arm
