Installing 75 Dash
Old Mar 8, 2018 | 07:56 PM
ScottEwine's Avatar
ScottEwine
Default Installing 75 Dash
I have been looking for any guidance on getting the dash back in a C3. I have the steering wheel/tilt/turn signal off and the column is disconnected so it can be moved down. I got the dash out with some grunting, now looking for help on getting it back in. All of the wiring is connected and checks out. Do you try to get the bottom in position first and then swing the top up into place or vice versa? I did this 20+ years ago on my 69 and the 75 is similar, but after messing with it for 15 minutes I think I must be missing something. From what I recall, the main wiring harness on the 69 was behind the gauges, in the 75 it looks like they go over the gauges.
Thanks, Scott
