Horn Relay Test
Old Mar 31, 2018 | 10:44 AM
V4motorsports's Avatar
V4motorsports
Default Horn Relay Test
I'm thinking my horn relay is not working, can someone please explain to an electrical idiot how to check mine?
Lower right is red, I'm assuming hot all the time.
Lower left is black, I'm assuming ground.
Upper left is green, I know goes to horn.
If I put power to just green wire, I get sound.
My assumption is...If I put steady power to lower right, hook up jumper from upper left to horn wire, then ground lower left, the horn should blow. Yes/No?
Thanks for any and all help
Russ
Old Mar 31, 2018 | 10:57 AM
henrikse's Avatar
henrikse
Yes you would be correct. If you just put B12 on red and touch N12 to relay you should here it click as it picks up. Then there will be 12 volts on contact to horn. Of course horn needs to be grounded
Old Mar 31, 2018 | 02:43 PM
V4motorsports
Thanks,
Horn is grounded. If I put power to just the green wire, the horn beeps. No matter how I try it, relay does not click.
Guess it's time for a new one.
Thanks again
Russ
Old Mar 31, 2018 | 03:22 PM
henrikse's Avatar
henrikse
If you have a test light or meter put B12 on red, N12 On black . Put test light lead on N12 and see if B12 on green. If not you need a new relay
Old Mar 31, 2018 | 05:12 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
The points(contacts) inside the relay are probably burned, take it apart and clean them.
Old Mar 31, 2018 | 05:46 PM
V4motorsports
henrikse,
As I said, I'm a complete idiot when it comes to electrical. I do have a test light but what is B12 and N12?
Sorry for not understanding.
Russ
Old Mar 31, 2018 | 11:41 PM
henrikse's Avatar
henrikse
Default info
B12 is positve 12 volt battery and N12 is negative 12 volt battery
Originally Posted by V4motorsports
henrikse,
Russ
To Horn Relay Test
