Rebuild Problem: Power Steering Control Valve
Old Mar 31, 2018 | 01:55 PM
Sammyf4g's Avatar
Sammyf4g
Default Rebuild Problem: Power Steering Control Valve
I rebuilt my PSCV on my 1980. All seemed to go well based on the Wilcox video and other info I read. When I put it back together, the ball stud turns so I can't tighten the stud to the pitman arm. Did I do something wrong in the rebuild? Any ideas before I crack it open again? Please help! Thanks.
Old Apr 1, 2018 | 03:37 PM
Haggisbash's Avatar
Haggisbash
Giving the arm a sharp tap with a hammer (and block of wood to protect paint) to seat it on the ball stud taper this should stop it from turning while you tighten it. Another way would be to start the engine and load the steering a little, this should stop the stud turning.
Old Apr 2, 2018 | 09:41 AM
Sammyf4g's Avatar
Sammyf4g
Thanks, Haggisbash. I'll try the hammer technique first. I didn't realize the ball stud was tapered. Thanks for clarifying that for me.
Old Apr 10, 2018 | 08:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
And just so you know in the future... Willcox has two L's... I often search for Willcox, but rarely search for Wilcox...
Willcox
To Rebuild Problem: Power Steering Control Valve
