1980 Hard to start
Old Apr 9, 2018 | 09:34 AM
Mike02z's Avatar
Mike02z
Default 1980 Hard to start
Picked up a 1980 L82 a few weeks ago. Finally got it running pretty good. The only issue mechanically is when it sits overnight it is very hard to start. It cranks fine but often takes 3-4 minutes before I can get it started. Once started it runs great and I can turn it off and even after a couple of hours it still starts fine.
I'm thinking maybe the fuel bowl in the qjet is leaking? The carb was rebuilt but has been sitting for 15 years.
Any suggestions?
Old Apr 9, 2018 | 01:22 PM
SwampeastMike's Avatar
SwampeastMike
Make certain that the choke is closing!
After a drive let it sit overnight or until STONE cold. Remove the air cleaner cover and pull back the throttle slightly. The choke blade over the front two (smaller) bowls should snap nearly shut leaving a 3/32" or so gap.
Old Apr 9, 2018 | 08:00 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Any suggestions?
grats on your new c3.
choke is a good suggesting so i will
ask what you are doing when trying to start.
3 min of cranking is a Long time.
hope you are resting the starter and not cranking
a long time at a try.
what makes you suspect the float?
do you experience with non fuel injected cars?
Old Apr 9, 2018 | 08:42 PM
av81's Avatar
av81
If the choke is closing but still cranks for 3 to 4 minutes look in the carb and hand pump the throttle to see if you see fuel spraying . .. if no the carb body might be porous and the fuel draining over night , I suspect the choke tho , the carb can be fixed if porous with epoxy so don't toss it.
Old Apr 9, 2018 | 10:26 PM
M Pete's Avatar
M Pete
I have a similar problem in my '80, however it doesn't take nearly that long. If I haven't bene driving in a day or longer it take about 10-15 seconds of cranking / pumping of pedal to get her going. After that she fires right up immediately until she sits overnight again. I just assume that is indicative of fuel line slowly leaking pressure once it is off.
3-4 minutes seems pretty extreme.
Old Apr 10, 2018 | 09:32 AM
stingr69's Avatar
stingr69
Forgive me if you already know this - Push pedal to the floor once to set choke, then turn the key and crank the engine. It should start. This is not fuel injection so you need to set the choke first.
If that is already known, verify the choke is closing when you set it.
If choke is closing, Open it with your fingers and check for fuel coming out from the accelerator pump when you work the throttle back and forth. You should see the squirt.
Old Apr 10, 2018 | 10:10 AM
Mike02z's Avatar
Mike02z
I should clarify. I don't continually crank for 3-4 minutes. It takes a while but I think I exagertated on the actual time to start it. It's more like crank for 15 seconds, pump the gas, crank for 15 seconds repeat. Once it does start, it will often stall when put in gear. Once warmed up, it runs like a top.
I was away but I'll check the choke today. I used to rebuild qjets about 35 years so you'd think I'd know how to troubleshoot starting issues by now This one looks brand new. I can see all the gaskets are new and the body of the carb is like new.
Thanks for all the suggestions guys. I'll post my results later.
Old Apr 10, 2018 | 06:22 PM
Mike02z's Avatar
Mike02z
Got home and pulled the air cleaner. Pushed the gas all the way to the floor. The choke was open close to 3/32's. Took about 3 trys at starting, 15 seconds of cranking each time. It fired up on the 4th try. If i put it in gear withjn 2-3 minutes it stalls. Seems fine once the temp starts coming up.
Old Apr 10, 2018 | 06:46 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
what weather temps are you dealing with?
cold? try 2 pumps of the throttle
warm? try 1/2 throttle to set choke
stalling could be choke coming off too soon.
what i am after is whether you are not giving the car enough gas for the weather temp or giving too much gas.
Old Apr 10, 2018 | 07:25 PM
Mike02z's Avatar
Mike02z
Garage temp has been in the 50's. It gets some heat as its under our bedroom. It has to run about 15 minutes or it stalls when putting in gear. Its an auto trans. Once it gers to temp, it runs great and starts immediately.
Old Apr 10, 2018 | 08:38 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
3 cranks isn't real bad but should fire off first time.
i would try a 1 1/2 to 2 pump to set choke.
15 min is extreme.
crossover in mani may have been blocked
thermostat may be too cold
idle to low
choke not coming off
guessing sucks
time for some investigation
Old Oct 10, 2020 | 12:06 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I am amazed that this issue (a frequent one and like a few other subjects) was answered in the first 3-6 posts. Yet it has been beaten to death again through 32 posts. Please put it in the "Sticky" section.
To 1980 Hard to start
