Radiator Support Question
Senior Member
Received 2,031 Likes
St. Jude Donor '10
Can anyone help me identify this radiator support?
I think it is a 68 small block but I am not sure.
If you can help to identify it I would appreciate it.
Thank you and best regards,
David Howard
David Howard
i would think one clue would be to measure the distance between the two lower radiator supports.
AllC34Me (04-23-2018)
Received 2,878 Likes
Hi,
The configuration of the two lower 'cradles' indicate that the core-support is for a copper radiator not an aluminum radiator.
Regards,
Alan
Regards,
Alan
My 6t8 SBC has that design. The original engine was a 350hp 327. There has been much discussion regarding radiators in the 68 model year. Some 350hp came with aluminum radiators some with the copper ones. A late 68 that I've worked on a BBC has an X cross brace but the same design as pictured. T
