Electrical issue-Help!
Old Apr 26, 2018 | 11:43 AM
Inca32x's Avatar
Inca32x
Default Electrical issue-Help!
Help!
4 way flasher - when turned on all 4 corners flash.
Turn signals - turn signal lever - left side front & rear light up but no
blink. Right side Light and blink.
Parking lights on -lights don’t light on left Front but do On left rear. Right side front and rear light up. Put left turn signal on and front and rear light up. With turn signal in the middle position right green arrow on speedo is lite up but go’s out when lever is moved down for right turn signal.
The green arrow on speedo is illuminated any time parking or headlights are turned on.
New bulbs in the front and rear make no difference. I have not done any work on wiring, happened out of the blue.
Any suggestions of were to start would be appreciated.
Old Apr 26, 2018 | 03:18 PM
Inca32x's Avatar
Inca32x
Found the problem, left rear bulb was in the wrong way!
