Steering Colum Install Help (Jim Shea Special)
Hey guys I’m having a similar issue that everyone seems to have on the forum with a rebuilt or a reinstall of the steering column. I had Mine rebuild. It’s a ‘74 tilt. The shaft isn’t long enough to engage with the flexible coupling. I’ve been reading through JIM Shea’s papers and I’ve tried prying on the length to get that extra inch. It currently measures about 3.5 inches. (An inch short according to the paperwork). I’m afraid to hammer on it because the rebuild was not cheap. I’ve read that people have pryed on it and hammered on it. What methods have you guys used to lengthen the shaft? How did you guys pry on it or how should I pry On it? Thanks in advance
Install #1
Removed after install
Install #1
Install #1
You could install a Flaming River U-Joint. Then your problem will be that your column is too long. I'll barely have threads showing at the firewall using the U-Joint and a Borgeson box.
Otherwise, slide hammer, pulling from the rag joint coupler? It looks like your column could be partially collapsed (compared to my 79 T/T before I shortened it).
Check out the thread from my earlier post. Others have had the same problem. Could be the shaft took a light hit while the column was out, drove it back into the column? Others mention ways to extend the shaft.
Another thought, is the flange where the column bolts to the firewall tight up against the firewall? Nothing interfering with the fit?
Went out and bought a pry bar. Reinstalled the column, and the coupler and tried to pry it forward but it keeps retracting back in. Is there something I need To loosen or remove for extend the shaft?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
None of this makes sense... put your coupling back together...
The steering column has plastic sheer pins inside of it that will allow the lower shaft to collapse into the upper shaft if you are in a front end collision... this helps prevent you from being speared if there is a collision..
Did these pins get damaged when you had the column out? I'm not sure.. but the re-builder should have caught this when he had the column apart.
If you put the coupling back together, then put some channel locks on the lower shaft you should be able to drive it downward so that you can get it back into the coupler.
IMHO,
Willcox
IMHO,
Willcox
I found an old thread that someone had solved the problem, I PM’ed him, he sent me pictures and the how to. So the secret is to get a gear puller, Install it between the flange and the column. Then take a wood clamp and wedge it between the puller and steering box. Slowly tighten the clamp and it slowly pulls the shaft out. I actually Used a pry bar because the clamp I had Was about an inch too long. So i took the pry bar between the clamp and used the booster/Frame and pulled until it was enough to bolt it down. In the above picture you can see the blue mark I made To measure the movement. Got that extra inch!
I wonder where the travel came from? If this works, great. I'm more curious as to where the travel came from.
Found this in Jim Shea's documentation, suggests the column can be compressed without necessarily breaking pins?
Steering Shaft Length Check
It is a good idea to check the length of the lower steering shaft #47. There are two
dimensions that can be checked; one while it is out of the column, the other when it is
assembled into the column. It is possible that the shaft could be compressed during
handling or when the steering column was removed from the car. The lengths for the
complete shaft are from the center of the yoke to the end of the shaft. If there is a
question as to exactly where the yoke center might be located, place one half of the
plastic centering sphere #46 in the yoke and measure from the flat surface
Former Vendor
How this happened and like I stated above..... makes no sense... The rebuilder of the column should have caught this unless it happened in shipping or something.
It's really odd to find a column like this unless it's been in a crash... and/or again like I said above, possibly it happened in shipping of the column.
The play came from the column being collapsed.. When the shear pins are destroyed the column will slip inside it's self by design... and the only way to get it to the correct length is to pull it outward and either re-melt the pins in place or just pull it where it belongs.
Yes, I think It was compressed an inch. I measured about 3.7 inches and extended it about an inch to get it to fit. I read Post after post of the problem and not a clear “how to” on how to get it back out.
