blinker issues, Bulbs good, Would like to replace flicker but cant locate it. Sound seems to be on Drivers side. No room on passenger side (where flicker was on earlier c3's).
Anyone know how to find flicker on 81 c3?
Does your emergency lasher work? If not recheck your bulbs. On my 80 the flasher is on the fuse block, lower right, the hazard flasher is on the upper left.
Could also be a grounding issue or a problem with the turn signal switch. Not enough info in the original post to knoe for sure.
I failed to mention the most obvious problem. Low blinker fluid, Amazon has it as well as most well supplied auto parts stores. One of many procedures to check fluid level.
