Lower Control Arm Question
Old May 16, 2018 | 06:13 PM
VirginiaVette78's Avatar
VirginiaVette78
Default Lower Control Arm Question
Gang,
In reassembly mode for my 78. Everything has a nice, fresh coat of paint and is going back on the car after getting all new bushings. Quick question on the lower control arms though - There are 2 front bolts and 1 rear nut and bolt to mount the lowers to the frame, on the rear nut and bolt, for some reason I cant get EITHER bolt to go on more than 1/4" (is this normal? thought it was weird that I would have screwed both up in the same spot!).. So, I have new ones on the way. But the real question is this - on the driver side, do you have to remove the PS pump to get that rear bolt out? I have browsed around the internet and found no mention of it from anyone.. I can always cut the old bolt out, but really didnt want to have to remove the pump to put the new one in...
THANKS!
Old May 16, 2018 | 07:00 PM
Mooser's Avatar
Mooser
Those nuts should be self-locking. The tapered end of the nut is deformed (triangle in shape) so they will thread on until they get to the deformed area and then tighten right up and need a wrench.
Sort of like a nyloc nut will thread on until it hits the nylon part at the top.
M
Old May 16, 2018 | 07:03 PM
Mooser's Avatar
Mooser
Like this if you look close
M
Old May 16, 2018 | 07:07 PM
VirginiaVette78
M
so, I'm just a dumb dumb who didn't put enough muscle into it - got ya!
I will try to put the originals back on again tonight then. Thanks!
Old May 16, 2018 | 10:34 PM
Mooser's Avatar
Mooser
For your other question, on my BB there's room above that bolt for removal so the SB it must sit differently
M
To Lower Control Arm Question
