Electrical Behavior
Old May 21, 2018 | 07:26 AM
haarvik's Avatar
haarvik
Default Electrical Behavior
So I decided to replace my exhaust from the manifold back. Dropped the starter to get to the collector. After putting the starter back on and connecting the harness back, I now have a buzzing noise behind the drivers seat, and the A/C fan turns on as soon as I connect the battery. Did not do this prior to dropping the starter. Any ideas what is causing this?
Old May 21, 2018 | 09:45 AM
bradleyb66's Avatar
bradleyb66
I think some (maybe all?) years have a ground wire on the starter - make sure you attached that wire back to a ground point, and not to an incorrect solenoid post?
Old May 21, 2018 | 11:54 AM
haarvik's Avatar
haarvik
Yep, connected correctly.
Old May 21, 2018 | 12:37 PM
bradleyb66's Avatar
bradleyb66
Have you looked to see what is buzzing? I'm guessing you have a later year (78+)? I don't know what years started putting electronics behind the seats, but I know the early years didn't have anything but wires back there.
Is it possible that you inadvertently 'fixed' a ground issue? The fan motor on 78+ is supposed to run on low speed at all times (at least with AC).
Old May 21, 2018 | 06:54 PM
haarvik's Avatar
haarvik
It's a 1981. The fan runs when I connect the batter, no engine running. I'm wondering if I got the connector on backwards at the temp sensor that is under the passenger side manifold.
Old May 21, 2018 | 07:05 PM
haarvik's Avatar
haarvik
Ok, so the connector was the issue with the fan. But the buzzing is still there. It comes from a circuit board with a silver box on top, about 2.5 inches square, in the jack compartment, and energizes a relay under the console. I can hear the relay click when the buzzing starts.
Old May 21, 2018 | 07:10 PM
haarvik's Avatar
haarvik
Found it. Wiper relay. So now the question is, why is it energizing when I connect the battery with no key in it?
Old May 21, 2018 | 07:54 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Check a wiring diagram for your year model to see which wire is accidentally supplying 12v to the relay with the key OFF.
(Member "Papawana" will email you a free wiring diagram if he has one)
Old May 23, 2018 | 07:25 AM
haarvik's Avatar
haarvik
I got it fixed. Ended up being a connector hooked up backwards.
Old May 23, 2018 | 08:36 AM
bradleyb66's Avatar
bradleyb66
Cool. Glad you found it (and thanks for updating!)
To Electrical Behavior
