'68 owners, need a quick measurement, please
And the amount of dish on a stock steering wheel?
My '68 came from PO with a 69+ TT column, and I am having a new column built without the ignition in the column. The supplier says their '68 Corvette column's position is the same as a TT fully extended, then I need a 2.5" adapter to accommodate my 6-screw steering wheel. I temporarily put the old column, pedals and seat back in so I could get a test fit (the interior is otherwise completely removed). It seems the extended TT length + 2.5" might be an OK racing position, but too close for a comfortable cruise. I think I may have them shorten the column and move the under dash mount back a few inches. I need to make sure that the head of the new column doesn't interfere with the lower dash pad.
This pic was taken before I removed the interior. It shows the dimension I am looking for.
The seats are Corbeau A4's. I got them through Speed Direct with their mounting brackets.... which were less than a perfect fit. The holes lined up fine, but you need to shim the brackets with a few washers so that the seat will slide properly. With the shaved cushion, I sit about an inch higher than in my old worn out seats. The back tilt is fully adjustable, but the forward/backward adjustment is limited, maybe 2-3 inches, but I think you would need to be less than 5' 5-6" to need to move the seat more than 3 inches forward in these cars. The side bolsters are thick so if your waist is more than 36" or so, that might be a problem. I'm pleased with them, but there are less expensive seat options available.
