Rear ebrake springs
Old May 22, 2018 | 06:22 PM
av81's Avatar
av81
Default Rear ebrake springs
was changing rotors and calipers one side had a broken spring man what a turd of a time replacing them ! Next time I would rather buy a new car
Old May 22, 2018 | 07:50 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Compress spring.
Tie it off with dental floss to keep spring compressed.
Position spring on shoe, slide pin through, put retainer cap on.
Burn floss to decompress spring.
Old May 22, 2018 | 08:10 PM
av81's Avatar
av81
Wow nice trick , I think the hardest was the top spring from shoe to shoe there is barely any room , it probably didn't help it was the last thing I was doing after working on the car 5 hrs on the floor on jack stands ... I need a lift or first a garage that one can fit .
Old May 23, 2018 | 03:46 PM
ronarndt's Avatar
ronarndt
Default ebrake springs
tool for top ebrake spring
The dental floss trick works well. there is also a tool that helps install the top spring. Ecklers and other vendors have it for about 10 bucks.
To Rear ebrake springs
