A couple engine questions
Old May 25, 2018 | 10:20 AM
drewwill's Avatar
drewwill
Default A couple engine questions
Hey y'all,
I had a fun experience the other day when my '76 decided to leave half of it's oil capacity on the interstate shoulder . From what I can tell, it all came out of that empty hole in the LS valve cover. I think that's supposed to be the PCV valve, correct? If so, what would cause it to blow out like that...? I've also attached a couple pictures of the casting numbers to see if y'all can help me identify the engine so I can get the right replacement part. the 3970100 casting number makes it seem like it could be the original block, but I'm not sure. Thanks ahead of time for all of the help!!
Last edited by drewwill; May 25, 2018 at 10:23 AM. Reason: Pictures were upside down
Old May 25, 2018 | 10:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
Std part number for a 350....believe GMPP still sells blocks. Why not upgrade to a roller block with the 1 pc rear seal?Sucks but nothing lasts forever. Consider putting a fan shroud on there, makes a big difference.
Old May 25, 2018 | 12:04 PM
Mr D.'s Avatar
Mr D.
Need to look elsewhere for oil leak, 2 1/2 qts of oil don't just jump out of a valve cover PCV hole.
Need more info. BTW, lose that death fan.
Old May 25, 2018 | 12:07 PM
drewwill's Avatar
drewwill
I was thinking the same thing. Can't find anything else so far, but it's gotta be related to it blowing the valve out, right?
Also, death fan?
Old May 25, 2018 | 01:45 PM
Scottd's Avatar
Scottd
How tight is that rubber grommet around the PCV valve? It may have just popped out or been knocked out the last time you were under the hood.
Old May 25, 2018 | 01:46 PM
drewwill's Avatar
drewwill
Umm, I need to find the pcv valve before I can answer that question.... I'll look for it again tonight.
Old May 25, 2018 | 02:13 PM
TimAT's Avatar
TimAT
PCV Valve is still in the end of the hose-- it's visible in your picture.
Old May 25, 2018 | 02:15 PM
drewwill's Avatar
drewwill
Wow. I feel really smart right now. Thank the man upstairs you guys are around. That probably would've taken me a week to notice.
Old May 25, 2018 | 04:05 PM
ezobens's Avatar
ezobens
I’d also look into rerouting the vacuum line for your PCV.
Having it ‘T’d into the vacuum line for the power brake booster is not good for either the booster or PCV function.
Just my .02
Old May 25, 2018 | 05:55 PM
63Corvette's Avatar
63Corvette
I'd bet you have a broken piston and you are pressurizing your crankcase
Old May 25, 2018 | 06:57 PM
drewwill's Avatar
drewwill
you would be correct. My phone isnt letting me post pictures, but there are several holes in the oil pan from the inside out. Im pretty sure this isnt good.
Old May 25, 2018 | 09:47 PM
Mr D.'s Avatar
Mr D.
You found your oil leak
Old May 25, 2018 | 10:49 PM
derekderek's Avatar
derekderek
Oil leak, light leak, parts leak...
Old May 26, 2018 | 09:51 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Any loud noises when the oil started leaking. something shot through the pan, I would think it made a lot of noise.
To A couple engine questions
