diff fluid c3 1972
Old Dec 30, 2018 | 01:54 AM
VCuomo's Avatar
VCuomo
What happens if you don't use the bottle of GM additive?
Old Dec 30, 2018 | 08:59 AM
Tampa Jerry's Avatar
Tampa Jerry
Assuming you have a posi unit, not using the additive will cause your posi clutches to grab unevenly and chatter making a bucking sound especially on turns. Jerry
Old Apr 30, 2019 | 09:47 PM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
I changed my rear diff fluid today. I followed the advice of a forum tech coordinator Gary (GTR1999) and used Lucas 85w140 Gear Oil with 2 bottles of GM posi additive.
I drained as much as possible, added the GM additive first, then the gear oil. It took a little less that a quart and a half of the gear oil (after the additive), before it started pouring out of the fill hole. Does this sound right? I'm not sure what the correct capacity is.
Old May 1, 2019 | 10:03 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Yes, thats the only way to get it in and once it back flows, you're full.
