80 Speedo Questions
Old May 30, 2018 | 11:40 PM
80-Vette's Avatar
80-Vette
Default 80 Speedo Questions
I have a 79 Speedo and the faceplate. Is it possible for me to just put the face plate on and change the speed gear in the tranny? I have been told the 79 Speedo is junk due to plastic parts but I really do not know if that is really the case.
The 79 Speedo I have has a broken needle and the person I spoke to suggested I ship both of them to him. He said it will make a rebuild easier because of having parts if needed.
To me it sounds a lot easier to just put the 79 faceplate on and change a gear if that is possible.
Old May 31, 2018 | 11:22 AM
80-Vette's Avatar
80-Vette
Someone should be able to answer this as I know I am not the only that has done this.
Old Jun 1, 2018 | 07:02 PM
DB Cooper's Avatar
DB Cooper
I don't see why you couldn't interchange parts between the two... they're both still cable-driven, aren't they ? This video from Willcox gives a good idea how everything comes apart and goes together. Also, if you aren't already aware of it, there are 2 speedo drive gears, the one in the tail of the transmission (drive gear), and the one in the speedo pickup on the trans (driven gear). There are a range of driven gear sizes that are interchangeable, so altering the ratio is easy to do without having to get into the trans to change the drive gear.
Old Jun 2, 2018 | 11:07 PM
80-Vette's Avatar
80-Vette
Thanks that clears things up for me.
To 80 Speedo Questions
