Unique parts on 1968 Big Block
Hello, new to Corvette Forum. Can anyone help me, what parts are unique to 1968 Corvette 427/435? I think so of the unique parts are: "4 Core Radiator", Larger "Sway Bars". Does anyone know the diameter of the Front and Rear Sway Bars? Are there any other unique parts? Thanks, Al
Received 6,943 Likes
2015 C2 of Year Finalist
if you have a copy of the AIM and open it up to the RPO L36 you can see everything the GM used to convert a base engine car to a 427 car. then the section RPO L71 you will see everything that was unique to that engine option.
cherrycorv (06-24-2018)
All 68's used a one year only core support, but 68 427's used the same radiator as 67 427's. The same front and rear sway bars were used with big blocks in most years. If I remember correctly, a 15/16" bar was usually used in front, and a 9/16" bar was used on the rear.
