1970 LT1 corvette with m-22 and 4.56 rear
Received 19,456 Likes
'20-'21-'22-'23-'24
Moved to C3 General.
My roommate in college had a 70 LT-1. It was around 1989. The car was original. Yellow coupe black inside. He bought it from a well known vette guy. It had a an M22 and 4.11 gears. I thought the ZR-1 had 4.11 gears? Anyhow, the only thing that separated that car from a ZR-1 (according to the guy he bought it from) was the J56 brakes., which it did not have. I recall not being able to keep it on the ground in 4th gear. What a ride. And yes, it was all original, Wonder who has it.
Joevette, did you buy that yellow 70 convertible with black vinyl hardtop that was on eBay? If so, I know the history on that car.
I don’t know what it came in/ from, but I bought a loaded differential that had a 4.56:1 RP. It was stamped as GM parts.
It appears the 4:56 gears were available in 1970 as well... page 91, https://www.gmheritagecenter.com/doc...t-Corvette.pdf
GUSTO
GUSTO
bobbarry (06-29-2018)
I think they did ( GM )
In 1970 4.56 posi was available, but only with the ZR1 special hi-performance engine package. I have 1970 ZR1 coupe and is one of 3 that I know of that came optioned with it in '70 (out of the 14 or 15 known cars in the registry). The ratio is documented by the interior build sheet listing the correct option code - BTW it's the only other variable option that was ordered on the car besides the ZR1 package and a tilt/tele wheel. It's a lot of fun to drive, especially with the lightweight flywheel and close ratio trans. Lots of throttle steer.
The following 2 users liked this post by 66L36Coupe:
lickahotskillet (03-14-2024),
moosie982 (05-12-2019)
