too much??
Old Jul 1, 2018 | 08:47 AM
walt4805's Avatar
walt4805
Default too much??
I have a 68 c3. I fixed the ac line then the compressor blew shortly after it was charged. So now I have replaced the compressor and the drier, I had the system open at both places. I install 8oz of pag oil and two cans of r134. It started to cool but then went warm so I add more coolant. Do I have too much in there? I also released air from the high pressure hopefully bleeding the lines of any air. Still nothing. And thoughts
Old Jul 1, 2018 | 09:39 AM
frodo84's Avatar
frodo84
Uneducated autodidact
Did you pull vacuum on the system before you charged it? If the system was open, that is required. You can't chase air out of it with refrigerant.
Old Jul 1, 2018 | 10:16 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Without pulling vacuum and without having the right equipment take it to an AC specialist !!
Old Jul 1, 2018 | 01:43 PM
walt4805's Avatar
walt4805
No I did not, tomorrow it goes to the clinic. Hey thanks
Old Jul 1, 2018 | 02:07 PM
dmaxx3500's Avatar
dmaxx3500
you might have added too much oil,,the system need the parts replaced,then vac'd and fill the right way
Old Jul 3, 2018 | 09:04 AM
derekderek's Avatar
derekderek
Might just be too much 134. Go get a hose kit with a pressure valve in it.
To too much??
