smog pump
If there is no catalytic converter installed then nothing bad will happen except some raw fuel exhausted to the environment.
"An air injection reactor (AIR) is used on some engines to provide additional oxygen to continue the combustion process after the exhaust gases leave the combustion chamber. An engine driven pump to provide pressurized air which is injected into the exhaust port of the exhaust manifold and then into the exhaust system.
"The AIR system operates at all times and will bypass air only for a short duration of time during deceleration and at high speeds. The diverter valve performs the bypass function, and the check valve protects the air pump from damage by preventing a back flow of exhaust gas. Diagnosis and service procedures for the air injection reactor system is in this section."
I know the old adage of "The solution to pollution is dilution." but in this case the AIR system isn't about dilution--it's about forcing the fuel to burn more completely.
I only have the '78 and '80 assembly manuals--not the '79.
The '78 shows the AIR system was not used for base engine (L48) Federal Emissions (non-California) and normal altitude cars. California, high altitude and ALL L82 engine cars had the AIR system. In 1980 ALL cars and engines had the AIR system. Something tells me that compression ratio and/or camshaft and/or timing and/or carb tuning made the difference between whether or not the AIR system was required to meet the requirements for a given year.
I know that AIR systems were used into the 2000s on some Northstar (Cadillac) engines and probably others. They may still be used in some circumstances. It may still be a "California thing"--I don't know.
