New rotors
Old Jul 4, 2018 | 05:32 PM
flyeri's Avatar
flyeri
Default New rotors
I am looking for new rotors. Has anyone used these? Brake Performance
I do not remember seeing these mentioned by anyone in the past. I have also looked at the Hawk Sector 27 rotors. I just need a good rotor with a coating to prevent or reduce rust and am open to suggestions. Both mentioned are in price range I want but if they are not pretty good quality I will pass them by. Thanks.
Old Jul 5, 2018 | 01:19 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
remember this front and back rotors appear the same for C3, they are Not the same, do not mix them up.
I installed rotors and pads on my suburban which really tests the brakes.
No problems, at all after a couple years. watch out for inferior imported Chinese rotors, they use cheaper materials.
Old Jul 5, 2018 | 02:20 PM
derekderek's Avatar
derekderek
Rotors aren't as bad as some parts when Chinese. They need to be a little soft. Wear items. The machining isn't as complex as most engine parts with much bigger tolerances between perfect and junk.
To New rotors
