there are tell tale signs,,
1.1 or 2 fuel lines
2.yellow/red-line of tach
3.u-bolts or caps on half-shaft u-joints
4.does it have a rear sway-bar
5.what size front springs
It has one fuel line it has the yellow red line tack it has caps on the U joints and a factory rear sway bar don’t know what size the front springs are but I know the front sits way too high
i assume 70 model year? And sits too high in front with a small block in it? What rpm does the yellow and red line say? It sounds like an orig BBC car.
