calipers
Old Jul 13, 2018 | 02:53 PM
haybail's Avatar
haybail
Cruising
Default calipers
I have a 1975 Corvette, I replaced the left front caliper, it was remanufacture and got it at the parts store. put in on with no problem brakes working just fine. Driving a little and the next day I check to make sure in was not leaking. But it was. it was leaking in the front where the to halves come together and where the O Rings are. Taking a closer look, the two halve look like they don't match. When they rebuild them don't they keep original matching set together. Any help would be greatly appreciated.
haybail
Old Jul 13, 2018 | 03:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by haybail
...the two halve look like they don't match....
Each caliper has two halves; they do not exactly match since one half has a bleeder.
...When they rebuild them don't they keep original matching set together...
Probably not.
Old Jul 13, 2018 | 04:15 PM
gbvette62's Avatar
gbvette62
No, caliper halves are not kept together during the rebuilding process. I've seen used calipers where one halve was an original Delco, and the other halve was an aftermarket replacement.
If you have your original calipers, the companies that deal in Corvette calipers can rebuild your calipers, but they charge an additional "tracking" fee, to make sure that the halves do stay together, and that you do get your calipers back.
Old Jul 13, 2018 | 04:25 PM
haybail's Avatar
haybail
Cruising
Thanks for all the above information
Haybail
Old Jul 13, 2018 | 06:48 PM
Greg's Avatar
Greg
Just another Corvette guy
haybail,
Did you buy from Autozone? They have had a real quality control problem with their rebuilt calipers lately. They used to use Cardone but recently switched, I believe to BBB Industries. I don't think their new supplier is sleeving the calipers. Lots of leakers.
Greg
Old Jul 13, 2018 | 07:27 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
O'Reilly isn't much better.
Old Jul 13, 2018 | 10:30 PM
Greg's Avatar
Greg
Probably the same supplier.
Old Jul 14, 2018 | 10:53 AM
cagotzmann's Avatar
cagotzmann
No better from corvette vendors. (unless you got calipers more than 7 years ago) Here is my pile of leaking calipers. even lonestar. lip seal or O-ring.
Now to be fare, these may have been fine for street only use, but the seals used in these products do not take the heat. I tested during 20-25 minute track sessions most calipers failed within the first year. (front), rears lasted 2-3 years.
I now have wilwoods on year 3 without any issues to date. Street or track days. Bad thing is they are costly.
Old Jul 14, 2018 | 09:05 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Original calipers aren' much better. I rebuilt my originals, but the two halves fit so poorly, being a machinist I resurfaced the mating areas to be parallel with each other and to prevent the pads from wearing out "on an angle".
Old Jul 14, 2018 | 09:11 PM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Another vote for Wilwood here.
Old Jul 14, 2018 | 10:59 PM
Bikespace's Avatar
Bikespace
I was happy with the Lonestars (via Zip) on my street/DD only 79. For my track(able) when complete 80, I was hoping to do the same. Aren't Wilwoods, the rears in particular, a bit of a pain to bleed? If stock calipers won't hold up to track use, I won't waste my time.
Has anyone attempted to spec their own O-rings? McMaster sells "high-temp o-rings" good to 450 deg F. Kalrez O-rings will go above 600 deg F, for the bargain price of $30- each (and up).
Old Jul 15, 2018 | 01:36 AM
cagotzmann's Avatar
cagotzmann
See my lonestar O-ring in the pile. I am sure they didn't use any of those O-rings. I guess you could try a rebuild. As for the wilwood rear bleeding they are a pain only the first time. I bleed ~ every 2 weeks between track days and have not had any problems after the first bleed. I also press the pistons in the caliper when bleeding. This also allows me to make sure no piston is stuck and moves freely.
To calipers
