Horn confusion
Here's the column with the hub removed. There is a bearing with this spring on it.
Then, over that, I had a turn signal cancelling cam. This is the first bit of confusion. Because I ordered a new one from Paragon and didn't get the same thing as I had. And I don't see how either one would work with the horn.
So there was a little circlip in a notch holding the white piece (in the above picture) on. Then the hub, then the top piece in the below pic was bolted to the hub under the steering wheel.
From the diagrams I've seen, I should have these parts:
But I don't have anything that looks like #1 and #2 and my #4 part looks different. Am I just missing #1 and 2? If so, I can't find a part number anywhere. And is my #4 part wrong, too?
When I got it, there was nothing connected, no horn button, nothing that would move. I got a horn button and it snaps into the center piece, but still wouldn't move (and wouldn't snap on with the steering wheel attached). My question is about the top piece in the picture (#4 in the diagram, I think?), since none of the diagrams show a part that looks like it with the metal leg sticking out the back. This leg doesn't seem to contact anything. Also, the little horn contact in the green cancelling cam doesn't touch anything. There are also (possibly) some other plates or things that didn't come with the car. I've found several diagrams and they conflict. Also, I suspect that some of the parts shown may be things that are already attached (maybe the mystery cover in a couple of the drawings is the black plastic piece that came attached to the canceling cam from Paragon, for instance). Obviously, I'm just frustrated that I have all these parts and all these diagrams and seem to get farther from the right answer the deeper I dig. Any wisdom would be much appreciated!
Nothing connected, no horn button, nothing that would move. I got a horn button and it snaps into the center piece, but still wouldn't move (and wouldn't snap on with the steering wheel attached). My question is about the top piece in the picture, since none of the diagrams show a part that looks like it with the metal leg sticking out the back. This leg doesn't seem to contact anything. Also, the little horn contact in the green cancelling cam doesn't touch anything. There are also (possibly) some other plates or things that didn't come with the car. I've found several diagrams and they conflict. Also, I suspect that some of the parts shown may be things that are already attached (maybe the mystery cover in a couple of the drawings is the black plastic piece that came attached to the canceling cam from Paragon, for instance). Obviously, I'm just frustrated that I have all these parts and all these diagrams and seem to get farther from the right answer the deeper I dig. Any wisdom would be much appreciated!
Look at this picture. My first arrow is pointing to a spring loaded rod which is part of a steering lock mechanism. I am not sure they had that in 1969. But your canceling cam would go on the column, then the locking plate, and it is held in place by that small wire clip that you have in another picture. We'll tak it this far for now. Let me know if this looks like it applies to your steering column.
Guess I need to hunt a lock plate for starters. It doesn't look like it's available from the major vendors. What year is your column? Thanks so much for the really useful picture.
You will need one with a round center, I believe what you have is for a tilt/tele. I remember having one with a round center on my '72 standard column, held in place by that round wire looking keeper that you have.
Keen parts has this one for a 69. I would call Keen to make sure that this is for a 69 before shelling out for it, or at least make sure you can return it if it does not work for your column. Parts seem very difficult to find for a 69. Another source for parts is SoCalVettes for some new and used parts. I have done business with them.
http://keenparts.com/corvette-parts-...partnum=350169
ON SECOND THOUGHT, I AM NOT SURE THIS IS THE CORRECT ONE, WE'LL HAVE TO WAIT TIL ASSEMBLY IS STARTED. SORRY.
Ok, I found a picture that will help. When you push on the dark piece/edge of the horn contact, it goes down and contacts the shiney flat piece, causing a short, which causes the horn to blow. You can see by how small that gap is that the horn button does not move very much at all to cause this contact to be made.
