Headlight problem.
Old Jul 22, 2018 | 11:03 AM
540 vette's Avatar
540 vette
Default Headlight problem.
Both headlights go on fine. When I put on the high beams the left front headlight goes out. The right low beam is on and the 2 high beams are on the left low beam is out with the high beams on.
Old Jul 22, 2018 | 11:08 AM
'75's Avatar
'75
Sounds like the low beam filament for the left outer light is bad, time for a new one. Could also be a bad contact at the 3 prong connector at that bulb.
Old Jul 22, 2018 | 11:56 AM
Richard454's Avatar
Richard454
Bulb or wiring?
A quick easy way to test- Plug the left side high beam two prong plug on the low beam headlight with three prongs- it will fit.
If it doesn't light up- then it's the bulb- if it lights up-then look at the wiring.
Richard
To Headlight problem.
