Gear Oil
Old Jul 27, 2018 | 11:22 AM
PHILB1's Avatar
PHILB1
Default Gear Oil
Hate to bring this up with all the confusion and contention I see out there, but here goes. I want to change out the Gear oil in my transmission and rear end. I think I should be using 80W90 GL4 gear oil. Not GL 5 or synthetic. I am looking to confirm. I have a 1969 427\390 M20 4 speed car. If GL4 is the preferred way to go, where would it be available?
Old Jul 27, 2018 | 12:17 PM
ddawson's Avatar
ddawson
My new transmission M20W warranty requires I use this.
Amazon Amazon
Old Jul 27, 2018 | 12:27 PM
ignatz's Avatar
ignatz
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have an old gallon of conventional StaLube gear oil on my shelf for just this purpose. My transmission repair guy told me to stay away from synthetics as the synchros would die a quick death.
Old Jul 27, 2018 | 05:45 PM
gguillot's Avatar
gguillot
After hours of research here on the forums, I went with the StaLube conventional oil in my '72 M21. Picked it up at the local NAPA.
Old Jul 27, 2018 | 05:52 PM
PHILB1's Avatar
PHILB1
Default Thanks
Thanks for the info, I will be picking some up this weekend
Old Jul 27, 2018 | 05:53 PM
VERYSOON's Avatar
VERYSOON
Stalube conventional in my M20 tranny, 1969 350. You can get it at Napa. If they don't have it in stock they will order it for you.
VERYSOON
Old Jul 28, 2018 | 08:10 AM
Bikespace's Avatar
Bikespace
I went with Red Line full synthetic, 75w90 GL-4. This, too, was based on much searching on the forum, and the ability to use the same oil in the (manual) transmission as in the differential. It seemed to improve the transmission, but I don't have any miles on the (Dana 44) differential yet.
Old Jul 28, 2018 | 05:40 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Go to the nearest Gm dealer and get there regular 75 90 weight grab oil and a bottle
of there additive. For the rear .
Old Jul 28, 2018 | 08:57 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
The Gearbox video with the Youtube channels all recommend GL4 and even have a video on why. The Synthetic is so slippery it wont stay on the gears long enough to make it back to the top and lube the bearings. On of then even had a unit returned with the bearings toasted because of no lube. I rebuilt mine last winter and can row through the gears as fast as I can with zero noise or grind. Its like butter
To Gear Oil
