Louvers
Old Aug 1, 2018 | 10:34 PM
CMoney1's Avatar
CMoney1
Cruising
Default Louvers
Hi I recently picked up louvers & need some help figuring out what corvette years it will fit. It does not have a maker that I can see, the middle section is made of aluminum & the sides are plastic. One picture shows some rough measurements of the louvers, I was hoping someone could provide the dimensions for the rear window of a 78-82.
Old Aug 2, 2018 | 06:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: if these are C3, they will fit only the big back window cars, 78-82.
Old Aug 2, 2018 | 09:38 AM
stingr69's Avatar
stingr69
60"???? (I was a draftsman so maybe that is just how I measure)
The 33" is right but the 60" is strange to me. Did you wrap the tape around the surface? Maybe more like 50" horizontal?
Old Aug 2, 2018 | 09:56 AM
CMoney1's Avatar
CMoney1
Cruising
The 60" is a straight line measurement from the underside of the louver from side to side, I will double check when I get home tonight.
Old Aug 2, 2018 | 01:18 PM
vettebuyer6369's Avatar
vettebuyer6369
the photos can be deceiving, but although they look just like C3 78-82 rear window louvers, Im thinking this set is actually for a C4, as they look wider than a C3 to me.
Old Aug 2, 2018 | 11:09 PM
CMoney1's Avatar
CMoney1
Cruising
It is 58.75"
Old Aug 3, 2018 | 08:05 AM
stingr69's Avatar
stingr69
Then they will not be for a C3.
To Louvers
