1980 4-speed clutch switch problem
Old Aug 2, 2018 | 09:17 AM
Sharky II's Avatar
Sharky II
Default 1980 4-speed clutch switch problem
won't crank even with clutch pedal pressed all the way
Old Aug 2, 2018 | 09:58 AM
Scottd's Avatar
Scottd
Assuming you have a good battery and getting power to the starter.....
1) Make sure there isn't something in the way of the clutch pedal. The carpet or floor mat can get bundled underneath it. (Actually happened to me)
2) MAKE sure you are in neutral. Check again, check a 3rd time, and make a jumper cable. If it cranks, you know its the switch.
There are a lot of other possibilities Id rule out before damning the clutch switch though. Id focus on battery, terminals and grounds first.
Old Aug 3, 2018 | 07:02 PM
righthanddrive's Avatar
righthanddrive
You can also use a jumper wire across the switch to check problem. Just make sure you either have the clutch in, or in neutral.
Old Aug 3, 2018 | 08:39 PM
Bikespace's Avatar
Bikespace
It's the battery. It's always the battery. Charge the battery (on a real charger, not a trickle charger). Only after that is done would I move on to anything else.
I can kill the battery in my 79 by leaving the door open for a few hours here and there while replacing the carpet. Lights still work, starter does not. Charge for a few hours, good as new! I am more diligent about using the battery disconnect now.
Or did you find it was the switch?
Old Aug 3, 2018 | 08:47 PM
69L46's Avatar
69L46
2015 C3 of Year Finalist
St. Jude Donor '15-'16-'17-'18-‘19-'20-'21-'22-'23
Just the fact your 1980 has a 4 speed =
Be curious to see what the culprit was.
Old Aug 3, 2018 | 11:33 PM
TimAT's Avatar
TimAT
Check the starter extension harness.
To 1980 4-speed clutch switch problem
