Reverse Safety Switch 68
Old Aug 5, 2018 | 07:48 PM
Thran69's Avatar
Thran69
Default Reverse Safety Switch 68
I've done some extensive research trying to figure out what reverse safety switch is on my 68 Corvette. I bought without checking this which i thought was the correct reverse safety switch. To my surprise, I found that we do not have any switch by the shifter. The switch appears to be bolted next to the transmission. Im not sure how many wires there is. I can go double check that if thats very important. It appears that this switch was put in when we restored the car as it came with the donor car. The car seems to have some trouble occasionally starting. I have isolated this to the switch due to slamming the shifter causes the car to start. I want to replace this as this is my show car, and i cant afford to be stranded.
Addditionally this car has been wired with a Painless Wiring Kit. Pretty sure that this came with new wires, so im not sure how my dad adapted to this wierd style of safety switches.
Heres the part that i bought.
Here is what I have
https://imgur.com/a/5QowXtA
Please help. Kinda lost, and so is my dad.
looking to buy a new one? Or should i retrofit it something more universal? Opinions?
Old Aug 6, 2018 | 06:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You purchased a neutral safety switch for cars with automatic transmissions. The switch mounts on the shift lever under the console.
Old Aug 7, 2018 | 04:40 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Originaly my 6t8 4-speed had a back-up light switch mounted by the tranny. T
To Reverse Safety Switch 68
