Hi all
I got my hands on a composite rear spring for a few $ and couldnt resist buying it since my old original is a little tired.
But the guy I bought it of had bought it used to, so the now I wanna have some help how to put it on my car.
I got a new set of bolts and new anchorplate and seems the compositespring is the same thickness as the original.
I seen some pics where there are some kind of plastic (nylon) between the spring and the anchorplate so I wonder is this a thing
come with the composite spring or...........?
Also what kind of torque are I using when put it on the car?
first you should identify who is the manufacturer of your spring. then look at their instructions.
Thats the problem no marking on the spring and the guy I bought it from dont know either.
If there were I would not ask here then I would go to the manufacture directly.
