tall guy is C3
Some background on me: I'm 6' 5" with a 78 L82 4-speed. The seats are from a 79-82. I drive in a slouched, knees up position. Turning left, my knee turns off the turn signal as I let out the clutch. At stop lights, I sit up straight and look over the windshield to see the light. Bigger bumps cause my head to hit the back of the birdcage. I've only had the T-Tops on about three times in five years and had to remove the interior panel of the top to give myself that extra 1/2 inch. I've actually, driven the car without the driver's seat. Seatbelt still works, feet easily reach the pedals, and I can see straight out the windshield. And the sport mirrors are useless --I get a real good look at the door handles.
Any thoughts?
I'm 6'2" and barely fit I am not sure how you even get in!!!! No first hand knowledge but I have read some forum posts and the answer is non corvette seats if I am not mistaken. Search the forums to see what you find. I also think some people have mounted the seats to the floor without the adjustment brackets to gain an inch or two. You didn't mention and it may be standard by that year but do you have a tilt column?If not you may need to add it. Good Luck
Also well understand the watching stoplights over the windshield header. I'm a bit of 6'3" so it's worse for you
Possibly remove the seat adjusters and mount the shell directly to the floor?
If you ever do want to drive with the tops get some glass ones as they have more headroom.
Some background on me: I'm 6' 5" with a 78 L82 4-speed. The seats are from a 79-82. I drive in a slouched, knees up position. Turning left, my knee turns off the turn signal as I let out the clutch. At stop lights, I sit up straight and look over the windshield to see the light. Bigger bumps cause my head to hit the back of the birdcage. I've only had the T-Tops on about three times in five years and had to remove the interior panel of the top to give myself that extra 1/2 inch. I've actually, driven the car without the driver's seat. Seatbelt still works, feet easily reach the pedals, and I can see straight out the windshield. And the sport mirrors are useless --I get a real good look at the door handles.Any thoughts?
If you come up with something that works I'd be interested to know.
Im turning 54 but had my first vette a 72 convertible at 16 17, and sadly i dont hop in and out like i did in my 20s
I also drove many small kit cars one had a roofline of 38" from the ground, 4" ground clearance, do that math, lol,
I feel cozy not cramped in my c3s, but i liked sitting in my 66 better,
I think its mrvette who is a tall cat with modded c3, he did glass work to extend the foot well and seems he dropped the floor under his seat, a common kit car trick,
SO, you have my sympathy and empathy......now, as for the car....
my car is a '72 vert, and owned it since '95.....many mods to it, see pix below....It has a TT wheel from a late shark, so the turn sig switch is on the column, and I cut the floorboard across the entire width, and up to the column height on both sides, pried the plastic forward about 3 inches, and glassed it in, your metal? flooring will require other ideas than simple glassing in.....after that, I cut the brake pedal arm and bent it forward about 3" worth, had a buddy weld it....and heated/bent the gas pedal lever too......another trick is in the back of my stock seats, I cut out the ~2" tall seat mount brackets off the slide tracks, and the end of the tracks just set on the floorboard...you maybe want to tie yours down, I never bothered, the front two bolts set on the floorboard not the carpet/padding.....I removed the seat belt cover for extra clearance, and of course used the OEM seat foam when recovering the seats, and deliberately weakened the seat bottoms a tad for another inch or so of lowered, and so at this point with the console pad I drive i the James Dean slouch position, right arm on the pad, hand on 8 ball shifter,....you just not cool unless you have an 8 ball on your shifter handle.....my car WAS a muncie 4 speed, but it got changed to a 200 4r auto for the overdrive here in Florida....
so the clutch pedal bit the dust long ago....small brake pedal is most convenient for my large shoe size....the late shark wheel with the pedals forward has plenty of clearance to my legs now....the car rides like my lounge chair...it's a bit of a rub/hassle getting in/out with the top up, but not so awful evil, and certainly not any worse than any other car....better than most, even vans/pickups/suvs' etc.....
Mirrors are from a late shark, and moved forward far as possible on both sides, and they are stuck in position with RTV black and I have small bubble mirrors on them, so I see it ALL at a glance, they take some getting used to, but hate not having them in other vehicles....
Use an AstroTop for tops on - it adds 2-3" of headroom
Use a Windjammer windshield extension to keep the wind off your forehead for topless cruising
You also have the issue with the seats, So going to a lower seat cushion, or decreasing the mounts may help. Since you obviously have the seat all the way back, then figuring out how to remove the railing and bolting the seat direct to the floor may give you added headroom.
kdf
The 78 is a 4 speed car and doesn't have tilt wheel so basically I can't drive it. When I let the clutch out my knee hits the steering wheel. I've often thought about adding tilt wheel to the car to solve this issue (I have a couple of used columns) but the car is so original and low miles that I don't want to mess with it. I've had other mt 78 and 79 cars and not had any issues but they all had tilt.
The other thing is the seats... the 79-82 style seat sits higher than the low profile original 78 seats so possibly you'd want to switch back to the original style seat.
With due respect, I'll admit that this is one of the most bemusing strings I have ever seen on this awesome forum.
