Question on RPM
Old Aug 31, 2018 | 07:16 AM
tomboyy's Avatar
tomboyy
Default Question on RPM
What should my RPM's be when I'm running 55-60 mph ? It's a '75 L-48
Right now it's doing somewhere in the 40 to 43 range. This seems somewhat high to me but maybe totally normal. I get feeling sometimes like I'm riding my bike and i need to catch another gear.
Old Aug 31, 2018 | 07:18 AM
derekderek's Avatar
derekderek
your tach is wrong. 4300 is screaming. either that or trans (auto)? doesn't shift and you are in second gear.
Old Aug 31, 2018 | 07:29 AM
tomboyy's Avatar
tomboyy
Its a 4-speed. At idle it is sitting at 1100 Which is a bit high but that makes me think the gauge is working. All I know about the engine is what I've been told by the PO. All the smog crap is gone along with the cat, it has SS headers and he said it had a slightly bigger cam installed. It will really get up and go in the higher RPM range.
Old Aug 31, 2018 | 08:04 AM
Gordonm's Avatar
Gordonm
Did the PO change the rear end gears?
Old Aug 31, 2018 | 08:11 AM
tomboyy's Avatar
tomboyy
That I don't know...I'm sorry I can't tell ya'll more but that's all I know.
What should the RPM"s be running 55-60 ?
And what if the gears had been changed...what would the reason for that be ? Except for the engine (matching numbers but worked on) and exhaust everything is original.
Old Aug 31, 2018 | 08:29 AM
Gordonm's Avatar
Gordonm
The rpms are dependent on the rear end gears. If it has 3.08 gears the rpms would be a lot less than if it had say 4.11 gears.
The tach boards on the electronic tach which yours should be have a tendency to go bad. Even though it is working they can show incorrect rpms
Old Aug 31, 2018 | 09:31 AM
Tiger Joe's Avatar
Tiger Joe
my money is on broken tach. to get over 4k at 60 mph you would have some serious gears in the rear, like 5.50s or the trans is stuck in 2nd gear.
Old Aug 31, 2018 | 09:36 AM
joewill's Avatar
joewill
1st get your a dwell tachometer meter.. 30-40 bucks on amazon and test that your car tach matches your new meter.
2nd. test your speedometer with your cell phone gps to conform that is correct.
then if all is correct and you are still running 4000 rpm at 60 mph then you have at or near a 4.56 rear end ratio.. 4.56 is basically not streetable.
a standard 3.08 rear gear the car comes with will get you about 2200 rpm at 60 mph.
if you are idling at 1100 then you probably have a pretty hot cam and a big street setup..
strange that the previous owner would not know all this.
this is all assuming you are using 4th gear?
Old Aug 31, 2018 | 09:42 AM
Bikespace's Avatar
Bikespace
Get a digital timing light to confirm your tach. You'll want one anyway, and this is the likely problem.
To check your rear end, put a tape mark on the driveshaft while the car is secure on jackstands. Have a helper count the tape marks as you turn a rear wheel one turn. 3.08 would be three Mark's and a fraction more. 4.11 four Mark's and a fraction more, and so on.
Old Aug 31, 2018 | 09:44 AM
revitup's Avatar
revitup
I believe 3:70 may have been the highest rear gear option and that would show roughly 3000 at 60 in 4th..
Old Aug 31, 2018 | 09:47 AM
Gordonm's Avatar
Gordonm
The standard gear ratio for a 75 L 48 with a 4 speed is 3.36. No way should it be turning over 4000 rpm. Again my bet is a bad tach. Verify as said above
Old Aug 31, 2018 | 12:34 PM
tomboyy's Avatar
tomboyy
Ok... I went out and bought a digital timing light, $100 later this is what I got.
gauge says 1200
timing light says 650 at idle
when I push it to 4000 ( gauge reading )
My timing light reads 2200
Checked the reading on my Silverado and they matched. So the timing light is right on.
The faster the RPM, the more it's off. So when I'm cruising at 60 the RPM's are really sitting at 22 - 23 not the 40 - 42 that the gauge is reading.
Thanks for the help guys.
Tom
Old Aug 31, 2018 | 12:41 PM
Gordonm's Avatar
Gordonm
gauge says 1200
Tom
That makes a lot more sense. Time for a tach rebuild. You can get a new board for them.
Old Aug 31, 2018 | 12:48 PM
derekderek's Avatar
derekderek
in the meantime now that you know you're at a normal RPM and the normal gear at a normal speed you can ignore the tack for the time being.
Old Aug 31, 2018 | 05:44 PM
tomboyy's Avatar
tomboyy
I don't know what all it entails, but I remember tearing dashes apart years ago and it wasn't fun nor something I want to repeat.
Old Aug 31, 2018 | 05:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thats factory tachs for you, even the C4 digitals can read high (those 7k shifts arent!). Youll get it fixed, worth it.
To Question on RPM
