78 coupe. Wipers shut themselves off when I turn on the headlamps. Turn headlamps off, they go back to working. They don't stop where they are, they go back to the park position.
This could be an issue with the headlamp switch, the connector or a ground issue. Is that all that's happening? Are the gauges still working when you pull the headlamps on? Usually this indicates a ground issue and the headlamps are seeking a ground.
[QUOTE=Willcox Corvette;1598018007]This could be an issue with the headlamp switch, the connector or a ground issue. Is that all that's happening? Are the gauges still working when you pull the headlamps on? Usually this indicates a ground issue and the headlamps are seeking a ground.
Willcox[ Thanks for your reply. Everything else seems to be fine, I was thinking ground myself, but have no idea where to start looking. I have heard of a ground terminal that is supposed to be up behind the dash. Just remembered the turn signal indicators on the dash don't work, but haven't since I got the car. They don't come on any time, head lights or not. Might just be bulbs, I just live with it.
