Fuse block
Old Sep 29, 2018 | 02:20 AM
Kim Roth-Franklin's Avatar
Kim Roth-Franklin
1st Gear
Default Fuse block
1978 C3 Could someone tell me where the fuse block is located and my interior dash light are very very dim Cause ??? Thanks
Old Sep 29, 2018 | 06:54 AM
Cooter Tech's Avatar
Cooter Tech
Drivers side foot well, just out of reach of a normal sized person. Being a contortionist will help accessing the fuses. Wrong bulbs, bad battery, bad ground(s). Make sure the lights are properly mounted. Check voltage at the bulbs.
Old Sep 29, 2018 | 10:55 AM
henrikse's Avatar
henrikse
try turning your headlight switch around and still dim?
To Fuse block
