I have a 73 with AC that has a bad blower motor relay, from what I can tell there are two types and I am not sure which one to replace it with.
One is a blower motor relay the other is a blower motor relay with cutout, both will fit just unsure of which one to use.
I need one for my '73 as well and after looking at the factory schematic and the relays available, I can't see a difference. All I've found (that have pics regardless of description) are 3 terminal with a separate terminal for the relay ground. I ordered a BWD R367 which will be here in a couple days, so we'll see.
