Carburetor Insallation
Old Sep 30, 2018 | 11:26 AM
mbp's Avatar
mbp
Default Carburetor Insallation
Hi. I was wondering about installing a M4 Rochester. What I would like to know, and can't find the numbers anywhere is the torque for the carb to manifold bolts/studs. All that seems to be said is that over tightening is easily done with bad results and just to tighten when installing. Wondered if there were torque specs. to prevent any broke bolts or studs or distortion to the carb mounting surface. Thanks to all.
Old Sep 30, 2018 | 01:08 PM
teamo's Avatar
teamo
https://www.corvetteforum.com/forums...que-specs.html
Old Sep 30, 2018 | 01:43 PM
maj75's Avatar
maj75
Make sure you have the correct base gasket and insulator (if needed).
To Carburetor Insallation
