Dash/Console Lights Issues
Old Oct 13, 2018 | 10:31 PM
Vols&Vettes's Avatar
Vols&Vettes
Default Dash/Console Lights Issues
Hey ya’ll. While driving at night, my console lights on my 1980 model recently went out and I smelled an electrical burning-like scent for a few minutes, then the smell diminished. After about 30 mins, the console lights came back on, and smelled the same electrical scent again. I was pulling up at the house and turned the lights off by this time. I changed the headlight switch today, and to no avail, as soon as I turned on the headlights, the console lights came on, same electrical smell, then they went out again. The headlights/turn signals/ running lights all work fine the entire time. Just the console lights (speedometer/tachometer/center gagues) go out. Any ideas on what to check next? Any advice is greatly appreciated.
Old Oct 14, 2018 | 10:59 AM
henrikse's Avatar
henrikse
I"ll tell you but you won't like. Not a fun job to remove the drivers side dash but you have a project. You have to drop the steering wheel column and support it. Then pull the speedo and tach cables. Remove headlight switch plug. Remove screws and take out dash. Label the wires with tape where they go to lights . Now you can look at wiring harness here. First see if any the wires are touching or welded together. Probably a short somewhere. Check if any wires are brittle. If you bend and insulation cracks you will need this harness. If ok you should find wire in question causing your short. Should be obvious. Pay attention to where tight curves in wiring are and note the clips that hold your wiring harness is routed to make easier to reinstall. All dash lights are grey wires I believe. Ground for this area should be cleaned. It is on right side pillar. While you have dash off if you want to do any speaker work (4x6) or door adjustments (top) now would be the time.
Old Oct 14, 2018 | 03:37 PM
SwampeastMike's Avatar
SwampeastMike
Fortunately '77+ has a one-piece dash that is FAR easier to remove. That said, I wouldn't remove the dash yet. There's a very good chance that the smell is coming from one of the flexible printed circuits used for the gauge pack and the speedo cluster. The problem is that their layers delaminate and allow the copper traces to touch--if just barely touching you'll get heat and the smell of burning plastic but the fuse won't blow.
Neither the gauge pack nor the cluster are particularly difficult to remove but they do take some time. Do some searching and/or ask questions if you're unsure how to remove them.
Old Oct 14, 2018 | 04:08 PM
Greg's Avatar
Greg
Just another Corvette guy
From what you've described, I would check your circuit protection first. If something is getting hot enough to give off an odor, it should certainly pop a fuse first. Is there a chance that the fuse for your dash lights has been replaced by one with too high an amperage rating or been bypassed/tapped into?
Start there.
Vols&Vettes
I appreciate the prompt reply. Just to make sure I’m following you, you are suggesting to check the printed circuits before taking the steps of pulling the dash and checking the wires/harnesses? If so, I’m not sure how to accomplish that. I’ve got a Factory Shop Manual on the way, but it hasn’t arrived, yet. I would appreciate any directions you or anyone could offer.
Old Oct 14, 2018 | 04:17 PM
Vols&Vettes
Thanks, Greg. I’ll check the fuse and all. When I test drove the car (twice) before I bought it, it all worked fine. There was no issues with the console lights, and certainly no smell. It started about a week ago. When you say “circuit protection,” what exactly do you mean?
Old Oct 14, 2018 | 04:27 PM
Greg's Avatar
Greg
Circuit protection, is your fuse panel.
Old Oct 14, 2018 | 04:55 PM
Vols&Vettes
Ok. 👌 I’ll get the manual and find the fuse for the dash/console lights and have a look at it. Thanks!
Old Oct 14, 2018 | 05:23 PM
Greg's Avatar
Greg
Should have a 5 amp fuse for the instrument lamps. But if it was replaced with a 25 or 30 amp fuse, this could be the problem. If not, at least the dash lamps are a fairly easy circuit to work with.
When this happens do your speedo and tach lights stay on or do they go out as well?
Old Oct 14, 2018 | 05:56 PM
Vols&Vettes
The speedometer, tachometer, and all center console gague lights go out. When I turn the headlight **** counter-clockwise to see if the overhead dome light and floor courtesy lights will come on, they won’t come on either. But the headlights, running lights and tail lights all work fine.
Old Oct 15, 2018 | 08:50 PM
Vols&Vettes
Greg, many thanks to you! I believe you helped me solve my issue. I checked the ‘Instrument Lamps’ fuse like you suggested, and there was a 10 amp fuse there. I pulled it and put a 5 amp in, cranked the car, but nothing. I noticed the tail lights, running lights were not on while the headlights were on. I checked the fuse for the taillights, and it was burned to a crisp. I replaced it with a fresh 25 amp fuse, and everything works like it should. I sat in the car for about 10 mins with everything on, and no burning smell and everything stayed on like it should. I checked the new 25 amp fuse just to be safe, and it was good. Is it possible that incorrect 10 amp fuse caused the other fuse to overheat or something, since those are tied in to the headlight switch as well?
Old Oct 15, 2018 | 10:33 PM
Greg's Avatar
Greg
Hard to say, I would only be guessing at this point, but I'm glad you're back up and operating.
Keep an eye on it and let us know if anything changes.
Old Oct 15, 2018 | 10:48 PM
Vols&Vettes
Sure will. (Actually it was a 20 amp I put in the tail lights, not 25 amp like I said earlier). But I’ll definitely let ya’ll know if anything re-occurs. Again, thanks to all the helpful information from all the replies!
Old Oct 17, 2018 | 05:50 PM
SwampeastMike
Good that it's working now but there's no way that an overrated fuse would cause the problems you described. I very much suspect that there is a tiny and intermittent short circuit in one of the laminated printed circuits that power the gauge pack and the cluster. The properly rated fuse [should] prevent serious damage--like a fire--but in the very likely event that the fuse blows you need to investigate further. While both of the circuits have the same problem I would start with the gauge pack. If you do wind up replacing that circuit, you need to use something like a piece of pasteboard (back of a scratch pad) to ensure the low fuel module stays in place. The replacement circuits (they actually seem superior to the originals) are significantly thinner and the low fuel module will easily come loose (at least it did in my '79).
Old Oct 17, 2018 | 06:07 PM
Vols&Vettes
Hmmm... Very interesting. Thanks, Mike. That is something I will have to check out.
To Dash/Console Lights Issues
