Engine code
Old Oct 16, 2018 | 08:10 PM
Bo sanders's Avatar
Bo sanders
8th Gear
Default Engine code
Hello I just purchased a 72 corvette I don’t believe the engine is original the front block numbers are V0204HN and the rear A279 and 3956618 is this a 69 300 hp 350 thanks in advance
Old Oct 17, 2018 | 06:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
HN indicates a generic passenger car engine. It is not a Corvette code. There could be a second number (VIN derivative) stamped on the pad.
Old Oct 17, 2018 | 07:25 AM
stingr69's Avatar
stingr69
'69 Passenger car 350-300 High Performance with TH350 transmission, Block Cast January 27th, 1969 and assembled in Flint Michigan on February 4th 1969.
Close application but not original to car.
Old Oct 17, 2018 | 09:45 AM
derekderek's Avatar
derekderek
And it also doesn't matter. Odds are something or everything have been replaced in that block and it is now a different engine than what it was 50 years ago.
Old Oct 17, 2018 | 10:14 AM
vettebuyer6369's Avatar
vettebuyer6369
Were you under the impression it was original when you bought it?
Old Oct 17, 2018 | 11:28 AM
Bo sanders's Avatar
Bo sanders
8th Gear
Default Engine code
when I bought the car the guy said he did not know if it was the original engine at least I got a decent engine not some 305 out of a late 70s car thank y’all for all of the replies
Old Oct 17, 2018 | 12:03 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Bo sanders
...at least I got a decent engine not some 305...
Corvette trivia: 1980 Corvettes going to California had 305s.
To Engine code
