Problems with my C3 electrical system.
Old Oct 20, 2018 | 10:53 AM
frC3's Avatar
frC3
Default Problems with my C3 electrical system.
My C3 has an ongoing electrical problem. Driving along and everything shuts down. Cools off and the clock runs backwards!!! Ugh!!! Has happened many times...
Old Oct 20, 2018 | 05:00 PM
C3 Stroker's Avatar
C3 Stroker
Seems your C3 came with the "time machine option". Flux capacitor needs replaced!
Old Oct 20, 2018 | 05:23 PM
sassc3's Avatar
sassc3
if only it was that easy
Old Oct 20, 2018 | 07:27 PM
vbgod1's Avatar
vbgod1
Shuts off, coasts to side of road and no power? Won't crank, no headlights, nothing? Or cranks and won't catch? Beginning a trouble tree here...
Old Oct 20, 2018 | 09:10 PM
henrikse's Avatar
henrikse
I would check the negative battery cable connection at battery and frame where it connects. Take right off frame and clean frame and eye and reinstall. Check positive battery cable at battery and at starter and ensure clean and tight. From there it goes to horn relay and coil. If above all good maybe the coil heats up and dies. Does it start after it coold down? Clock runs backwards? weird but it would have to be polarity reversal to clock to reverse motor.
To Problems with my C3 electrical system.
