'79 light bulb sockets
Old Oct 23, 2018 | 03:53 PM
Fastclient's Avatar
Fastclient
Default '79 light bulb sockets
I pulled my center dash on my 1979 and I am missing a few light bulbs and socket holders. Checking the web it appears they takes a 5/8" Hole Twist Socket. Is that correct? Do some instruments lights take different size sockets? Is there some other description I should be looking for. Any help would be appreciated
Measuring the socket hole 1/2" seems to be the correct size. Unless I hear otherwise Im going to go with that
Old Oct 23, 2018 | 04:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Just a heads up, if the car doesn't have a low fuel warning module in it.... don't put a socket and lamp in it's place, leave it out or add the module, it belongs in there. But if you put a standard bulb and socket in that hole the light will stay on all the time if you don't.
It'll look like this unless it has my reproduction in it... then the board would be green and not clear-ish.
Next...
On a 1979 there wasn't any socket for the hole below the seat belt warning socket, it was left empty.
The socket was a 1/2 in twist locking socket that used a 194 bulb.
Willcox
https://willcoxcorvette.com/
http://repairs.willcoxcorvette.com/
Old Oct 24, 2018 | 10:19 AM
Fastclient's Avatar
Fastclient
Thank you, thank you. I didn't need an additional socket, just one of the bulbs was in the wrong place. There was a bulb in the check engine and since mine is a '79 no need for it to be there. Just moved that bulb to the empty slot where there was supposed to be one. Thanks again Willcox!
To '79 light bulb sockets
