1982 engine stamp pad
Old Oct 27, 2018 | 09:23 PM
pltmgr's Avatar
pltmgr
Default 1982 engine stamp pad
Can you see it without removing anything?
Old Oct 28, 2018 | 09:15 AM
Lakeside49's Avatar
Lakeside49
I am curious, as well. Seems hidden by A/C and its anti-smog components when searching, even using a mirror & light.
Old Oct 28, 2018 | 01:32 PM
2TONE82's Avatar
2TONE82
Yes, it is possible without removing engine components...but depending on condition of the motor you may need better access to remove grease and grime to actually see the stamp. I'd show you a picture but I'm not with 82 today.
You are looking for a pad on the engine block just below the smog pump and a/c compressor. Follow the valve cover on passenger side to the front of the engine and look below where the head meets the block. I've used a rag, long handle screw driver and spray cleaner such as 409 to clean the pad when checking out a car.
To 1982 engine stamp pad
