Modified wiper switch
Old Nov 5, 2018 | 08:35 AM
lakerider57's Avatar
lakerider57
Default Modified wiper switch
I have a 1980 corvette and had several wiper-related issues but got all the issues fixed except the wiper switch.
I bench tested the switch and proved bad so I opened it up and cleaned it and re-assembled it according to Willcox instructions but still didn't work (only washer worked). I then ordered a new switch ($83) and it didn't work, not even the washer function which at least worked on the previous switch. I opened up the new switch and found the washer didn't work because the stem which pushes out the center contact was too short. So I gave up on the old technology in the switch.
I decided to go with a newer rotary switch from Cole Hersee, here it is mounted in the existing wiper location (kinda looks like it belongs there ?)
http://colehersee.com.au/product/win...ff-park-lo-hi/
The wiring on the back side:
and what the final product looks like from driver's view:
So what I have is a rotary switch which supports Park and Low speed but I don't have High speed (I can deal with that).
The switch also supports the washer function via pushing in on the **** like the original switch function and I added an Led bulb like the original switch had.
I believe I paid $12 on-line for the rotary switch which is probably more reliable and I believe fits in quite nice.
What do you forum members think ?
Richard
Old Nov 5, 2018 | 12:49 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
It's better to be safe for now......later on you might find a correct replacement with high speed setting
(Did you ohm test each wire to see if there is a bad/corroded connection.....I use the "wiggle method"--car battery disconnected/connect the ohm meter to one wire/slightly wiggle the wiring bundle under the dash and in the engine bay to see if continuity is intermittent for each wire that connects to the wiper switch)
Old Nov 5, 2018 | 01:54 PM
Greg's Avatar
Greg
Just another Corvette guy
Nice upgrade
Old Nov 5, 2018 | 01:55 PM
lakerider57
Yep, I tested thoroughly the OEM switches and followed Willcox's papers to the tee. I figure as the years go by, the OEM switches will just get more rare and expensive and now I have something that is better technology and a lot cheaper.
Richard
Old Nov 5, 2018 | 01:56 PM
lakerider57
Originally Posted by Greg
Nice upgrade
That's what I hoped you would say and not the "Bubba" word...
thanks
Old Nov 6, 2018 | 07:01 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
good job, Bubba would have used speaker wire straight to the alternater and put power to the ground lugs. thats how mine melted when i bought the car and tested the wipers
Old Nov 6, 2018 | 07:56 AM
lakerider57
Now that's funny, almost made me spit out my coffee this morning
Richard
Old Nov 6, 2018 | 10:30 AM
Doug Kraft's Avatar
Doug Kraft
Nice. I did the same thing to mine with the same switch.
To Modified wiper switch
