80 factory 4
Old Nov 16, 2018 | 08:05 AM
  #41
tukawuka's Avatar
tukawuka
Which 6 speed you using?
Old Nov 20, 2018 | 01:28 PM
  #42
MIKE80's Avatar
MIKE80
T56 pulled from a 94 Trans Am.
Old Nov 20, 2018 | 02:17 PM
  #43
tukawuka's Avatar
tukawuka
what revs at 70 mph?
Old Nov 20, 2018 | 02:55 PM
  #44
MIKE80's Avatar
MIKE80
Not sure at 70... about 1550 at 60 mph in 6th gear with 3.70 rear end.
Old Nov 20, 2018 | 06:20 PM
  #45
tukawuka's Avatar
tukawuka
Yea, gonna yank my tranny, What do you think of the Tremec 5 speed or the Doug Nash 6?
Old Nov 21, 2018 | 12:43 PM
  #46
MIKE80's Avatar
MIKE80
Since yours is very original, I would go with one of the 5 speed bolt in kits offered by some of the vendors, and keep the original parts. This way it could be returned tot stock if desired. I had to cut my tunnel for the T56 install, but only cost me about $1000 for the swap. One of the best upgrades that can be done to the C3 is the 5 or 6 speed with hydraulic clutch.
Old Nov 21, 2018 | 01:22 PM
  #47
tukawuka's Avatar
tukawuka
Agreed i looked into tremec 5 pro kit no mods to the tunnel or consol, direct fitment, easy R+R 2500 plus the kit. Did u change the rear gears? I got 3:07 in there now.
Old Nov 28, 2018 | 12:54 PM
  #48
MIKE80's Avatar
MIKE80
Yes, I swapped the rear when I had the body off. Also dropped in a 385 stroker engine. Here's a couple pics of the installed T56 trans.
