Difference between 72 and 73 frame?
Old Nov 10, 2018 | 03:57 PM
62corvette's Avatar
62corvette
Default Difference between 72 and 73 frame?
How does a 72 frame differ from a 73? Or does it? Thanks
Old Nov 10, 2018 | 09:40 PM
BarryB72's Avatar
BarryB72
My guess is there may be a hole or 2 on each frame horn in a different location due to the different frame extension.
I know I had to drill holes in the 72 frame extensions to line them up on a 75 frame.
Guess you could drill out new holes in the frame and weld others shut so it's not noticeable.
The radiator shroud bracket bolt holes may need drilled in a 73 frame for it to work on a 72.
Old Nov 11, 2018 | 03:59 AM
hunt4cleanair's Avatar
hunt4cleanair
In addition to the frame extension, rubber cushion body mounts were used, replacing the metals discs. Thus there were adjustments made to accommodate ride height.
Old Nov 20, 2018 | 03:28 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
The frame dimensionally is the same, the front extension horns are slightly different. If you are willing to open up some holes you can get a 72 frame to work fine on a 73 and without much work. If you remove the rear bumper brackets from a 74 frame you can get it to work for the 73 as well. Going out beyond 74 gets much more involved.
Good luck with your search.
David
Old Nov 20, 2018 | 05:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1968-1973 frame dimensions.
To Difference between 72 and 73 frame?
