72 vette, wider wheels
Any help is better than none,
You might want to mention the width and diameter of the wheels you will be using to get a more meaningful answer.
i.e., If you are using a 8" wide wheel (with 5" of back spacing), a 1" spacer with locate the wheel in the stock position... but that probably doesn't answer your question either...
Good luck... GUSTO
A 1" adapter will clear the control arm and spring and but also move it 1/2" further out board with your 8.5" wide wheels, which should clear your inner fender edge.
https://wheeladaptersusa.com/collect...rvette-s10-cts
You might want to post a picture of the wheel center/lug nut interface so we can see if the wheel is hub-centric or lug-centric. This would help to determine what type of adapter you should use. Corvette rally wheels were both hub and lug centric. The Corvette alloy wheels were hub centric.
Good luck... GUSTO
Wheel spacers are the DEVIL. I'm a mechanical engineer and an ex-scca crew-chief.
Basically wheel spacers are BAND-AIDS for incorrect wheel purchases.
Get the correct size and offset for the vehicle and forget wheel spacers.
Having two mating surfaces on one aluminum wheel, with an aluminum spacer and long studs can promote deflection and movement.
Ask yourself....do you ever see RACECARS with wheel spacers????
"you picked a fine time to leave me loose wheel"
Unkahal
I feel it is essential to keep the same wheel center line to keep the loading on the suspension to stock specs....bushings/bearings struts, etc......I measured from wheel flange where weights would be clipped on to the mounting flange....7" offset for the '89 wheels......2.5" adapter which of course uses 10 bolts per wheel to get to the rotor surface, like shown above.....so net offset at 4.5 inches.....
stock rim measured same way....3.5" offset......don't forget the rim/wheel is 9.5" w vs 8" wide and to boot the aluminum is thicker than the steel where the tire mounts/flange....
so my wheel centerline is the same......NOW I had to move the ebrake cable, I went behind the rotor, others go on top.....at any rate, it's outta the way, the tires just clear the stock thinner sway bar, and the chassis.....in front I had to limit the steering radius to keep tires off the sway bar/frame....not by much, never notice it in driving....still tighter radius than a C4.....
