Winter C3 Storage Blues
Pls post pics of your hibernating C3 tucked-in for its too-long Winter slumber!
But, it won't be that way all winter - we try, and always have done, to use it at least once a month all through the winter, providing the roads are dry and there is no salt. The later is easier here in France as we don't use it as much - but alas, we do not live in the south, so we do have to pick our dry days
That said, you can bet that when we head out on a Corvette Club France trip in the summer we'll be lucky to have perfect weather for the entire week or so!
So it was spring, March, VT.....'hard pack driveway'....months of working on the car, fingers cracking, joints aching....and now a brilliantly sunny and dry day!
Alright! Lets drive the puppy!
Hard top off, Check!
Convertible down, check,
Heat on, check!
Gas chemistry, Check!
Tire pressures! Check!
Fluids A-OK!
Back the side-exhaust car out of the garage, small block echoing through the hills....
And It sunk to its axles in my driveway!
ARGH! 'Mud-season'.
And so I moved to PHX!
I feel!
Unkahal
Parts storage shelves. I'm going through them now an loading the work benches
VB&P front ans rear suspension setup on the work bench
the bay window has 2 Qjets under the rags waiting to get rebuilt or sent to Lars if I screw them up. My pup is buried on the hill outside that window so she is close
Firsst winter project is complete The hoist system worked great and should help me out alot this winter
Pulling the hood solo. My Dad usually helps out but I was in a groove and I could grab him if I got hung up
rolled easily to the back of the car and rested the nose on a heavily padded bracket mounted to the garage door side that stays closed.
just lowered the nose on to the wall hanger then strapped up the top
winching the top off with a ratchet
rotated it around the windshiled and rolled it to the work area up front. I sat in an office chair and bolted the brackets on the top. Nice and comfy
your pics walk away with the C3 double-take award! Love 'em!
Are you in the winter picture with the lady and t-tops off in the sub-zero looking weather? And, how in the ...heck did you set up those realistic-looking snow plow shots?
Thanks for sharing those good laughs...
DV
hey Eddy, my snow removal days ended the day we moved to TN
