Engine code suffix
Old Nov 20, 2018 | 09:49 PM
Phathom69's Avatar
Phathom69
Default Engine code suffix
Does anyone have any idea what application this engine came from. It looks like V1024OLE I could not locate that suffix anywhere.
Old Nov 21, 2018 | 06:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Are you sure it's an alpha O?
Old Nov 21, 2018 | 06:26 AM
Phathom69's Avatar
Phathom69
No I’m not sure. I’m looking to buy this block and heads to rebuild and I’m going off the seller info the heads are cast as 3782461 this be asked him for a pic of engine code but says he can’t get it till the weekend.
Old Nov 21, 2018 | 05:37 PM
derekderek's Avatar
derekderek
I think OLE is a mexican block.
Old Nov 21, 2018 | 05:44 PM
derekderek's Avatar
derekderek
I also think a 461 is a collectors item head. Valuable to the right guy if the date code works. Overpriced to anybody else. Old heads need guides and seats. Easy to spend 4-500 on a head. Just to have old school stuff. Brand new Vortecs or iron Dart heads are a way better option. You can get into aluminum heads for not much more. The block? A block is a block. No real diff between this old 350 and that one.
To Engine code suffix
