lift
Old Nov 21, 2018 | 03:40 PM
Booga's Avatar
Booga
8th Gear
Default lift
Where would the lift points be on both a 1970 & 1965 Stingray. I plan on alternating the two vehicles on a Bendpak 6xp scissor lift, for storage purposes, thank you.
Old Nov 21, 2018 | 04:03 PM
L-46man's Avatar
L-46man
Because both chassis are essentially the same;
JUST in front of the rear trailing arms on the outboard frame itself...flat part.
Slightly behind the front wheels on the flat part of the outer frame perimeter.
Use the available rubber pads.
Be aware that one of the worst things you can do to a Vette is to lift one corner at a time.....either one SIDE or one END, but not a corner!
Good luck be safe!
UnkaHal
Old Nov 21, 2018 | 04:39 PM
Booga's Avatar
Booga
8th Gear
Thank you for the info, all 4 corners will be lifted simultaneously. I did find an illustration that showed 5" back from the front wheel well, 3" in front of the rear.
Old Nov 21, 2018 | 04:42 PM
L-46man's Avatar
L-46man
poifect! don't forget the rubber pads.....the frame is slippery metal-to-metal.
I used to have a car called the 'Booger Rabbit'.....the car that woudln't er ah 'flick-off'! lol
Happy -t-give.
UnkaHal
Old Nov 21, 2018 | 05:26 PM
Booga's Avatar
Booga
8th Gear
Yes for sure, I even thought of placing washcloths under each pad, but I guess the rubber is made of oils and so forth. Happy Turkey day to you too
Old Nov 21, 2018 | 07:05 PM
Hardscrable's Avatar
Hardscrable
What rubber/lift pads do you recommend for jacking a C3 ? I have never seen a “commercially” available pad for a Vette older than a C5.
Old Nov 21, 2018 | 07:37 PM
Booga's Avatar
Booga
8th Gear
I hope I just didnt spend $2300 for nothing
To lift
