C3 body mounts
Old Nov 21, 2018 | 06:33 PM
John Brady SR's Avatar
John Brady SR
3rd Gear
Default C3 body mounts
Is there any way to replace body bushings with the body in place?
Old Nov 21, 2018 | 09:18 PM
kansas123's Avatar
kansas123
Read this entire post to find some info on what you are trying to do. There are other posts with information also, just do a search for 'body mount'; look at posts older than the last entry on this post, as I have already scanned the others. Good luck.......
https://www.corvetteforum.com/forums...placement.html
Old Nov 22, 2018 | 08:49 AM
The13Bats's Avatar
The13Bats
The cat i swapped engines with had lived in apartments before buying his house with shop,
In the apt parking lot he pulled and lifted the body of his wifes 73 just enough to change the bushings,
would haul all his tools in and out to work on it.
So it can be done....
Old Nov 22, 2018 | 08:54 AM
croaker's Avatar
croaker
I did the one side at a time method. Not to bad . Power Blaster is a great help.
Old Nov 22, 2018 | 09:07 AM
sambrand's Avatar
sambrand
take your time, work slowly and give yourself 5x the amount of time you imagine its going to take, it can be done but theres a zillion things that go wrong and its a lot of slowly raising one portion of the body, bracing it for safety then working on it then re attaching it. if you rush this job or fail to properly brace the body each time you replace a mount your risking crushed hands or crimpled/broken body panels/paint. note of caution here if you do have the body come down unexpectedly you can become trapped there until someone finds you.
To C3 body mounts
